Offset animated texture map
I have loaded an animated texture/color map ( for exemple: 0 to 100.tif) , how i can offset it so that the animation begin only on some frames later . In the same way , how is it possible to keep the last frame holded?
Thank you.
Sylvain.
Edited by sly
it's all about expressions in filename
if your path is
path/filename.0.tif - path/filename.100.tif
you can use `$F+offset`
path/filename.`$F-10`.tif
if your path is
path/filename.000.tif - path/filename.100.tif
you need to pad the frame number so if you want to offset it will be like
path/filename.`padzero(3, $F-10)`.tif
to hold last frame you can use min(offsetFrame, maximumFrameValue ) function
path/filename.`padzero(3, min($F-10,100) )`.tif
to hold first frame you can use max() function in the same way
to hold both ends you can use clamp(offsettedFrame, minimumFrameValue, maximumFrameValue)
path/filename.`padzero(3, clamp($F-10,0,100) )`.tif
