houdini viewport VS flipbook image save
I don't think there's color correction done at all when flipbooking. If the colors look "right" in mplay (when set to a display gamma of 1.0), then it has sRGB baked in. Then you can apply a gamma value of 1/2.2 to convert it to linear.
hi,
I guess my viewport has sRGB color and when I do flipbook and open up the image it looks like lenear.
How do I change flipbook output images color space change?
There are two ways to do this:
  1. The flipbook dialog has a Gamma setting on the Flipbook tab that you can adjust to bake a gamma into the images (2.2). If you save the images from MPlay, they will have the gamma baked into them.
  2. You can flipbook the images without gamma and use MPlay's gamma to correct the images. If you save the images, they will not have the gamma baked into them.
