dark_cry Posted May 30, 2012 Share Posted May 30, 2012 Hi, i'm using H12 and i have some problem with motion blur... i did some heavy rigid body sim and writed out as bgeo, and imported it back and when i'm rendering there's no any motion blur. The same problem with inctansed particles. I used copyed some several geo to particles with copySop and cached it as bgeo and imported it back. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 30, 2012 Share Posted May 30, 2012 Check that the velocity attribute exists and has valid information. This can be done with the "Details" view or by right clicking on a SOP and selecting "Spreadsheet" from the menu. Quote Link to comment Share on other sites More sharing options...
dark_cry Posted May 30, 2012 Author Share Posted May 30, 2012 Check that the velocity attribute exists and has valid information. This can be done with the "Details" view or by right clicking on a SOP and selecting "Spreadsheet" from the menu. There's no velocity attribute... Quote Link to comment Share on other sites More sharing options...
kare Posted May 31, 2012 Share Posted May 31, 2012 There's no velocity attribute... while writing geos, go to copy sop-> click attribute tab-> check template point attributes -> in To Point set v attribute and any other attributes if u want to use.. Thanks, kare Quote Link to comment Share on other sites More sharing options...
dark_cry Posted May 31, 2012 Author Share Posted May 31, 2012 while writing geos, go to copy sop-> click attribute tab-> check template point attributes -> in To Point set v attribute and any other attributes if u want to use.. Thanks, kare Thanks man Quote Link to comment Share on other sites More sharing options...
dark_cry Posted May 31, 2012 Author Share Posted May 31, 2012 while writing geos, go to copy sop-> click attribute tab-> check template point attributes -> in To Point set v attribute and any other attributes if u want to use.. Thanks, kare And what about rbd sim? Quote Link to comment Share on other sites More sharing options...
kare Posted May 31, 2012 Share Posted May 31, 2012 And what about rbd sim? enable Geometry Velocity Blur in geometry level for your dom sim. Quote Link to comment Share on other sites More sharing options...
dark_cry Posted June 1, 2012 Author Share Posted June 1, 2012 enable Geometry Velocity Blur in geometry level for your dom sim. you know i wrote the rbd sim to bgeo... and loaded it back, and enabled the velocity blur but there no any effect Quote Link to comment Share on other sites More sharing options...
kare Posted June 1, 2012 Share Posted June 1, 2012 you know i wrote the rbd sim to bgeo... and loaded it back, and enabled the velocity blur but there no any effect its easy to solve, if you post a sample file... Quote Link to comment Share on other sites More sharing options...
