etudenc Posted June 14, 2012 Share Posted June 14, 2012 (edited) Hi all, I've put together a pretty simple demo of what I'm trying to do. In the picture you'll see a top-down view of a wireframe grid and a bunch of instanced grids that were created using a popnet to copy SOP from the wireframe grid as it rotated around a pivot. In a nutshell I want the instanced grids to inherit the master grid's orientation. Is there a way to do this *other* than sorting the points and using $TX2-$TX/$TY2-$TY/$TZ2-$TZ in a point SOP to set the normals? In this example I know it would work, but if the number of emitting faces is changing every frame then the points would be less orderly and not line up. As always, any suggestions would be greatly appreciated! Thanks! orient_copiedGeo.hip Edited June 14, 2012 by etudenc Quote Link to comment Share on other sites More sharing options...
bloomendale Posted June 14, 2012 Share Posted June 14, 2012 Hi all, I've put together a pretty simple demo of what I'm trying to do. In the picture you'll see a top-down view of a wireframe grid and a bunch of instanced grids that were created using a popnet to copy SOP from the wireframe grid as it rotated around a pivot. In a nutshell I want the instanced grids to inherit the master grid's orientation. Is there a way to do this *other* than sorting the points and using $TX2-$TX/$TY2-$TY/$TZ2-$TZ in a point SOP to set the normals? In this example I know it would work, but if the number of emitting faces is changing every frame then the points would be less orderly and not line up. As always, any suggestions would be greatly appreciated! Thanks! Hi. Do you mean copy, not instance? Possible solution: 3ak_orient_copiedGeo.hip Quote Link to comment Share on other sites More sharing options...
sadhu Posted June 14, 2012 Share Posted June 14, 2012 (edited) One more solution.. orient_copiedGeo.hipnc Edited June 14, 2012 by sadhu Quote Link to comment Share on other sites More sharing options...
etudenc Posted June 14, 2012 Author Share Posted June 14, 2012 Thanks so much for the help, guys. I realize my example was too simple so I've made some adjustments. This time the master grid is being moved along a path so I don't think I can query actual rotation values coming from the xform. I still want the copied geo to get its orientation from the face it's essentially being copied from. Is there some way I could set the normal of a point based on where it was in the previous frame? Or is it possible to transfer the normal of the "emitting" primitive to the point inside the forEach? Hope that's clearer. What I'm actually trying to do is lay down tire tracks from tires that were translated/rotated in Maya. I'm grouping faces on any tire tread that enters into the boundary of a cube, finding their centers and emitting particles to copy to, like what you see in the attached example. Thanks again! orient_copiedGeo.hip Quote Link to comment Share on other sites More sharing options...
Rudinie Posted June 15, 2012 Share Posted June 15, 2012 Something like this? orient_copiedGeo_moreorless.hip Quote Link to comment Share on other sites More sharing options...
etudenc Posted June 16, 2012 Author Share Posted June 16, 2012 Something like this? Thanks, yeah that's much closer. I tried a different solution by subtracting point 0's position from point 1's position on each primitive inside the forEach, then setting an "up" vector based on the result. An attrCopy SOP copies that normal back to the final fused point of each primitive that gets sent to the POP SOP (way easier to see in the file than to explain in words). For my purposes this seems to work better for cases where the number of "emitting" primitives changes from frame to frame. Thanks for looking and for all the help, folks. orient_copiedGeo2.hip Quote Link to comment Share on other sites More sharing options...
Rudinie Posted June 18, 2012 Share Posted June 18, 2012 How about not using particles at all but just using a sopsolver, like in this example. sopsolver_for_trails.hip Quote Link to comment Share on other sites More sharing options...
etudenc Posted June 19, 2012 Author Share Posted June 19, 2012 How about not using particles at all but just using a sopsolver, like in this example. Thanks for uploading the example. Haven't used the sop solver at all so between your file and the Peter Quint videos I should be better informed very soon. Thanks again! Quote Link to comment Share on other sites More sharing options...
anim Posted July 9, 2012 Share Posted July 9, 2012 ...I still want the copied geo to get its orientation from the face it's essentially being copied from. ... it there a reason why you don't precompute N and up values on your source mesh? then it will be transformed automatically with object merge or if you don't want to do that you can do something like this to get orientations of faces from arbitrary poly geo also better way to detect center points of faces may be to use divide sop instead of forEach orient_copiedGeo_to_faces.hip Quote Link to comment Share on other sites More sharing options...
