Macha Posted June 26, 2012 Share Posted June 26, 2012 (edited) Why does the gas wavelets microsolver scale its results? It looks like it creates an octree of its results in a field. Edited June 26, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
bunker Posted June 26, 2012 Share Posted June 26, 2012 You need a setup with two Gas_Wavelet nodes, like in the gas_upres eg: 1 - gas match field : Wavelet > Density 2 - gas wavelet : Wavelet > Density ( Transform ) 3 - gas wavelet : Wavelet > Wavelet ( Extract Component ) try to change Level and Components ... On 6/26/2012 at 5:34 PM, Macha said: Why does the gas wavelets microsolver scale its results? It looks like it creates an octree of its results in a field. Quote Link to comment Share on other sites More sharing options...
Macha Posted June 26, 2012 Author Share Posted June 26, 2012 Cool, and volume border type has to be set to constant. So, now, what do we do with it! Maybe we could mask out by frequencies if we had a little more interesting wavelets than the box shaped Haar. Man, Julien, I wish I could watch over your shoulder one day! Quote Link to comment Share on other sites More sharing options...
mrWolf Posted October 8, 2013 Share Posted October 8, 2013 Hi guys, sorry to reopen this old thread, i hope someone is still listening I am trying to upres a cloud sim using "gas wavelet". I am not using Pyro or Smoke. I create my cloud using a poly geometry and the "cloud sop". I created a velocity field matching the cloud , to add some turbulence and created a simple dop network where I am advecting ("gas advect field") the density with that velocity and removed the divergent component of the velocity field ("Gas Project Non Divergent Multigrid"). Everything works fine, and I like the sim. What i don't like is that the simulation is smearing / smoothin out all the cloud features. I'd like to know how to re-insert some of those details using, if I well understood its purpose, "gas wavelet" dop. I tried to apply what Julien explained in the previous post: - i created a field "wavelet" (float) matching "density" using "gas match field" dop - i created 1 "gas wavelet" dop : dest field="wavelet", source field="density", mode="transform" , everything else default (Haar, Max Passes, Level, Component = 1,0,0) - i created 1 "gas wavelet" dop : dest field="wavelet", source field="wavelet", mode="extract component" , everything else default (Haar, Max Passes, Level, Component = 1,0,0) I am not sure what I have to do next I am not even sure if a density and a velocity fields are enough to create my wavelet up-resing. I know, i should study the paper about wavelets written in 2012, but honestly i didn't undertand much.. I checked the example files included with the documentation about the upres dop node, but they all refer to "Pyro" or "Smoke". I didn't find a way to upres a generic volume sim. Can anyone help me here ? Quote Link to comment Share on other sites More sharing options...
mrWolf Posted October 14, 2013 Share Posted October 14, 2013 no love for this topic ? Quote Link to comment Share on other sites More sharing options...
Drughi Posted April 23, 2020 Share Posted April 23, 2020 Hey @mrWolf, have you found a way? Quote Link to comment Share on other sites More sharing options...
