cloudfx Posted July 7, 2012 Share Posted July 7, 2012 I have a grid with some part $CR attribute value. Used Popnet and set Source with "Surface(attribute)" and in Distribution Attribute, I tried CR , Cd but it seems it's not working. In help window did not gave me enough info. How to get it work? (hip file attached) sourceAttri_v01.hip Quote Link to comment Share on other sites More sharing options...
Hello world Posted July 7, 2012 Share Posted July 7, 2012 I have a grid with some part $CR attribute value. Used Popnet and set Source with "Surface(attribute)" and in Distribution Attribute, I tried CR , Cd but it seems it's not working. In help window did not gave me enough info. How to get it work? (hip file attached) hi use $CR in the birth probability in the source pop Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted July 7, 2012 Share Posted July 7, 2012 You have to set the birth probability to 0 and $CR sourceAttri_v01_EP.hip Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 8, 2012 Share Posted July 8, 2012 You can promote the Cd point attribtue to the primitives and use this attribute as Distribution Attribute. source POP looks at primitive attributes Quote Link to comment Share on other sites More sharing options...
