jkunz07 Posted July 10, 2012 Share Posted July 10, 2012 Does anyone know the math being done behind the Drag POP ? The docs state that the drag is proportional to the speed of each particle, so would a VOPPOP equivalent be something like multiplying the current velocity by 0.95 or some fraction of 1 depending on amount of drag? Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted July 10, 2012 Share Posted July 10, 2012 (edited) Does anyone know the math being done behind the Drag POP ? The docs state that the drag is proportional to the speed of each particle, so would a VOPPOP equivalent be something like multiplying the current velocity by 0.95 or some fraction of 1 depending on amount of drag? I believe it is really just a multiplier. I've asked this question before and got no responses, but one way to verify would be creating two identical particle systems and use a drag pop on the first and a vop pop on the second. Cheers PS: on a second thought, I do believe the drag pop takes mass into consideration... Edited July 10, 2012 by rafaelfs 1 Quote Link to comment Share on other sites More sharing options...
gaurav Posted July 10, 2012 Share Posted July 10, 2012 (edited) I dont know how drag pop really works but intuitively it should be dependent on both the speed of the object and the square of its speed. drag = −1*normalize(v)*( C1 *|v| + C2 * |v|^2) Drag with C2 value will grow faster as the speed gets higher. At least thats what seems to be with air drag that keeps things from accelerating to infinity. At slow speeds there is little drag from the air, but for 2x of the speed the drag will be 4x as it increases. just a thought. Edited July 10, 2012 by vectorblur 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted July 10, 2012 Share Posted July 10, 2012 I believe it is really just a multiplier. I've asked this question before and got no responses, but one way to verify would be creating two identical particle systems and use a drag pop on the first and a vop pop on the second. Cheers PS: on a second thought, I do believe the drag pop takes mass into consideration... Thanks, this is a cool trick when replicating POPs in VOPs. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 11, 2012 Author Share Posted July 11, 2012 Thanks, this is a cool trick when replicating POPs in VOPs. Yeah, that's what I was after. Here's a file with some useful particle operations implemented in vopsops and a solver sop: solversop_particlevops_v001.hip Lemme know if anyone finds any of the vopsops particularly useful or if anyone has any feedback. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted July 11, 2012 Share Posted July 11, 2012 Thanks John, that looks great. Would be good to have all the POPs implemented this way for everyone to see Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 11, 2012 Author Share Posted July 11, 2012 Thanks John, that looks great. Would be good to have all the POPs implemented this way for everyone to see No problem, some of that file is direct ports of stuff from the Cinder flocking tutorial which explains some of the math/concepts behind flocking systems very well in my mind. 2 Quote Link to comment Share on other sites More sharing options...
magneto Posted July 11, 2012 Share Posted July 11, 2012 Thanks John for sharing that link. Looks like a good resource. Basic POPs should be easy to implement in VOPs, but I am wondering if anyone has ever implemented interparticle collisions in VOPs? That would be pretty sweet Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 13, 2012 Author Share Posted July 13, 2012 Thanks John for sharing that link. Looks like a good resource. Basic POPs should be easy to implement in VOPs, but I am wondering if anyone has ever implemented interparticle collisions in VOPs? That would be pretty sweet A type of repulsion or avoidance behavior shouldn't be that hard to implement in vops, should be as straightforward as point cloud filter nearby particles and adjusting accelerations of particles within a certain radius of each other. I'll let you know if I have any success with it. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted July 13, 2012 Share Posted July 13, 2012 Thanks John, that would be awesome. I need to dive into point clouds myself too Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 13, 2012 Author Share Posted July 13, 2012 Thanks John, that would be awesome. I need to dive into point clouds myself too Here's a quick implementation solversop_particlevops_avoidance_v001.hip If any particles get too close to each other (within the search radius of the vopsop parameter) they push away from each other. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted July 15, 2012 Share Posted July 15, 2012 Thanks John, looks very good. I will have to carefully examine it Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted July 23, 2014 Share Posted July 23, 2014 (edited) I dont know how drag pop really works but intuitively it should be dependent on both the speed of the object and the square of its speed. drag = −1*normalize(v)*( C1 *|v| + C2 * |v|^2) Drag with C2 value will grow faster as the speed gets higher. At least thats what seems to be with air drag that keeps things from accelerating to infinity. At slow speeds there is little drag from the air, but for 2x of the speed the drag will be 4x as it increases. just a thought. excuse me mr rabit, or anyone who knows, does the C's in the equations means constants?, and anyone knows a similar fomula for angular drag? i too have been having troubles with drag force dop Edited July 23, 2014 by willow wafflebeard Quote Link to comment Share on other sites More sharing options...
