Collision Event
tuangD
Hey Tuang. The collision event is generated by particles. if you check on the geometry spreadsheet in your POPs editor, you should see a field which has Collision information. (If you have Collision POP, that is)
The Particle SOP does it as well, but I think you'd have a better control of the collision in POP. Depend on your need, tho.
  • 14 years later...
