import .MDD from Marvelous Design problem
Hi everyone,
i created a cloth animation in marvelousDesigner.
When i import this .mdd animation file into houdini, i obtain a error message in my node: can not open mdd file "E:/winwin/.… » it may be missing or corrupt.
And i can create and create mdd file from Marvelous Designer, it’s always this problem.
I’m not only to use marvelous designer,I don’t find topic on this problem..
Someone can help me please?
Thank you
Best regards
do you have any other app which supports mdd and try it there too ?
my first guess wd be that the object you are applying mdd to could not have the same order of points like the one you generated the mdd ..
try 'keep points order' or something similar when you export your obj file too .
sometimes strange things happen to me too when i generate mdd and export object as obj from other 3Dapps ..
but as Michael said , uploading a small sample might help ..
.cheers
