anupamd Posted September 13, 2012 Share Posted September 13, 2012 Ok so Im trying to have a flag that is waved around (think of it like a checkered flag on a race car finish line). I dont want to use cloth, and I dont want to use particles. I think I have a technique that will work. Basically I need to look at the point position at a previous frame and weight that point position by say the U value of the Flag UVs. That way the base sticks to the pole and the tip "lags" behind a few frames. My problem is how do I get access to point position from a previous frame or from "N frames back"? Once I have that, I can multiply that by a weighting value and Im pretty much done. Any suggestions or samples would be appreciated. Quote Link to comment Share on other sites More sharing options...
J.Santos Posted September 14, 2012 Share Posted September 14, 2012 This might do the trick for you: http://www.sidefx.com/docs/houdini9.5/nodes/sop/spring If you scroll down you'll notice that the Spring SOP has an example with a flag... Hope this helps! Quote Link to comment Share on other sites More sharing options...
glfloat Posted September 15, 2012 Share Posted September 15, 2012 Thanks for the response. The spring sop uses simulation.. its basically a spring solver in sop level. The technique Im talking about is basically a lag or delay on the lookup of the point position a few frames back based on a weighting value. With that technique there is no simulation required and is very fast. Its a common technique used in motion graphics. I suppose my question boils down to how to look up position of points n-frames back. The point expression does not allow you to get the point position at a certain frame. So I'd have to use chf or something else. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
Marc Posted September 15, 2012 Share Posted September 15, 2012 lag CHOP would be my first thought. Quote Link to comment Share on other sites More sharing options...
old school Posted September 18, 2012 Share Posted September 18, 2012 If you want to use the previous frame's state to derive the current frame's state, no matter how you slice it, it's a simulation. This opens up the door to the Spring SOP as mentioned above. CHOPs as Marc mentioned is a bit of a different beast but too caches the flag pole's animation where you can derive motion on the geometry. If you use CHOPs in timeslice mode, then it too becomes like a simulation where those CHOPs that require to look a bit in to the past (Lag CHOP, Spring CHOP, etc.) will do so but not force the entire simulation to cook. There is the Solver SOP that will give you direct access to the previous frame's motion but again this is a simulation where the current frame is dependent on the previous frame's state. Quote Link to comment Share on other sites More sharing options...
