Rigid Body Tutorials
I finally found how to make more than one rigid body .
It's not very natural but it can sound Houdinically logical.
To create a RigidBody, it's quite simple:
at the Object level, select RigidBodyDynamics and select the Object you
wanna make a rigid body. That's it!
It creates a RBDcreate Pop in a Popnet and a ParticleChop in a dedicated chopnet.
Now, how to add another RBD:
Just Go into the created Popnet and add another RBDcreatePOP (with an another object to refer to).
To apply a force to the first RBD, append a ForcePOP to it and to make the second RBD for example a passive rigid body (like a wall), append a Property Pop to it ( set the Mass to 0, and the other parameters to whatever you want, just play with them).
Now (and that's the important thing) merge the two incoming Pop with
a CollectPOP. It links the rigid bodies.
Hit play and see the result.
That's all about it!
If anyone has other tips...
