stopa Posted October 4, 2012 Share Posted October 4, 2012 Hi all, As a total houdini newbie , I have a problem with exporting particles. After doing some experiments with popnetwork, I would like to export my work to 3ds max and render with krakatoa. After some search I know that this is possible to do with Realflow plugin, but I don't know how. I tried to connect realflow nodes to popnetwork, but after clicking render nothing happens. I would be very grateful, if someone could explain me how to do it. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 4, 2012 Share Posted October 4, 2012 Check out the documentation that comes with the RealFlow plugins, they cover everything you need to know. You could also use Alembic if Max supports it or write your own file format with Python. Quote Link to comment Share on other sites More sharing options...
stopa Posted October 5, 2012 Author Share Posted October 5, 2012 Check out the documentation that comes with the RealFlow plugins, they cover everything you need to know. I'm doing everything according to the documentation (add RF particles export node, select the output file and SOP path, I leave Particle File tab with default options) and after clicking render button nothing happen. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 5, 2012 Share Posted October 5, 2012 Which version of Houdini are you using? Which operating system? Are these the plugins from Next Limit or are they from Digital Cinema Arts (http://www.digitalcinemaarts.com/software/real-flow-plugins/)? --Mark Quote Link to comment Share on other sites More sharing options...
stopa Posted October 5, 2012 Author Share Posted October 5, 2012 I am using Houdini 12 for windows. I am using plugin from NextLimit site. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 5, 2012 Share Posted October 5, 2012 I am using Houdini 12 for windows. I am using plugin from NextLimit site. If you use the Houdini File SOP or a ROP to write out the cache does that work? It might not be something with the plugins but something with the network leading up to the plugins. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 5, 2012 Share Posted October 5, 2012 Can you post a hip file for us to look at? Quote Link to comment Share on other sites More sharing options...
stopa Posted October 6, 2012 Author Share Posted October 6, 2012 If you use the Houdini File SOP or a ROP to write out the cache does that work? It might not be something with the plugins but something with the network leading up to the plugins. SOP and ROP work fine. Can you post a hip file for us to look at? Of course I can : http://www.filedropper.com/untitled_15 Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 7, 2012 Share Posted October 7, 2012 Hmmm ... I downloaded the latest rf plugins from Next Limit but got this: Houdini DSO error on '/opt/hfs/houdini/dso/ROP_RF_Sd_Export.so' Compiler incompatibility detected. gcc compiler versions below 4.3 are not compatible with gcc compiler versions 4.3 or above. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 7, 2012 Share Posted October 7, 2012 Of course I can : http://www.filedropper.com/untitled_15 There's not much to your example, a single pop op and an rf export node, thus it's hard for us to help. --Mark Quote Link to comment Share on other sites More sharing options...
skogen Posted October 8, 2012 Share Posted October 8, 2012 Maybe helps: Houdini 2 Krakatoa http://code.google.com/p/h2k/ (Worked for me) PartIO http://redpawfx.github.com/partio/ Cheers! 1 Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 8, 2012 Share Posted October 8, 2012 Both of those file formats are points/particles only, no mesh. partio is very nice though. Quote Link to comment Share on other sites More sharing options...
stopa Posted October 10, 2012 Author Share Posted October 10, 2012 Maybe helps: Houdini 2 Krakatoa http://code.google.com/p/h2k/ (Worked for me) PartIO http://redpawfx.github.com/partio/ Cheers! Thank you skogen! That is what I'm looking for! Could you be so kind an explain how to install this Houdini 2 Krakatoa plugin? I'm looking everywhere but i can't find any instruction. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 10, 2012 Share Posted October 10, 2012 The h2k won't work for H12 until the code is updated. The partio code has to be built into a SOP ... RFE for SESI maybe? --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 10, 2012 Share Posted October 10, 2012 Both of those file formats are points/particles only, no mesh. ooops, thought I was replying to a different thread regarding Real Flow mesh files .. Quote Link to comment Share on other sites More sharing options...
