how to mantra render with no camera motion blur?
I don't know if there is an easier way, but you can remove the values that a channel takes between integer frame numbers. For example, if you have an animation on channel ry then you can counteract for the interframe values with an expression in a parented null that corrects for the channel like so:
chf("../null1/ry",$FF+1)-chf("../null1/ry",$F)*1[/CODE]
Your camera will now move in jumps in that channel, from frame to frame, and therefore remove motionblur. You can even blend it in if you change the *1 value in the above expression.
Edited by Macha
  • 2 weeks later...
  • 4 years later...
3 hours ago, rbowden said:
Should just be Xform Time Samples yeah?
Render Properties -- Rendering -- Xform Time Samples.
Thanks!
For those following along, on the camera: Render Properties --> Mantra --> Rendering --> xform_motionsamples
Edited by LukeLetellier
  • 3 months later...
I'm doing some custom particle trails (taking into account the camera transforms) to do some more detailed motion blur effects. This means I don't want any blur on the particles (geo or camera).
However, I still need the holdout geo to have all of it's normal blurring. Anyone know if this is possible? Essentially, can you have camera blur on one object and not on another? I've tried all of the object specific render parms I can think of but no luck yet. Could just not be doing the right combination of settings.
Cheers, Carl.
