Fluid source, alembic file
mrcain
Possibly a simple one here, but I can't scatter/source from an alembic file ? Just gives me a bounding box.
Same file imported as obj works fine, but obviously doesn't carry all the animation.
Anyone had issues with this ? Work arounds ? I've written the geo out as bgeo and imported back in but still no dice.
Cheers
Found out it was a problem with my alembic file.
Also not sure it's the case with all abc files but it didn't have any velocity information in it. Plus was also a big drag to read
in all the animation on every frame, slowed it down too much. Fixed now though.
Cheers!
  • 9 months later...
I usually change the alembic to "use houdini geometry" (inside the alembic options). Its actually pretty nice
that now Houdini 12.5 supports UV information in the alembic file so you can export it to any software that
supports alembic and rock on ;)
Oh, almost forgot to mention that scatter points from source on alembic object doesn't work in the latest build of Houdini, it will be fixed (hopefully) in H13. :P
I personally prefer 12.5.316.22
Edited by theviolator
