abvfx Posted November 29, 2012 Share Posted November 29, 2012 Hey ther, just a quickie that i hope some of you know the answer to. How to properly comp SSS so you can get back to a beauty render. On the left is the beauty render, on the right is me trying to combine the different elements to get it back to beauty. The separate planes were Diffuse - per light, Indirect Bounce - These are simply added together Single SSS + Multi SSS - First process - These are inverted and then multiplied to the diffuse, Second process - It is then separately multiplied to the result of the inversion. (See pic) Paint - Multiplied to the combined diffuse + SSS Spec - These are added over everything So what am i doing wrong? Hope this forum still lives. Thanks. Quote Link to comment Share on other sites More sharing options...
eetu Posted November 29, 2012 Share Posted November 29, 2012 I haven't tried it, but I would think that the SSS should be added? Quote Link to comment Share on other sites More sharing options...
abvfx Posted November 29, 2012 Author Share Posted November 29, 2012 Yeah that was one of the first tings i tried. I did some investigating in the mantra shader to see how it was applied. I now add the combined SSS to the specular, and that is added to the diffuse * color. Its much more closer but there is still a subtle difference. It may be small but it is a difference nonetheless and would optimally like to find out how it is being applied For those also quietly trying to help, don't stop, i will post a solution if i find it Quote Link to comment Share on other sites More sharing options...
