houdini snow solver
fayal
  • 1 year later...
Check the SNOW_Solver.h file at the beginning :
* The simplest network to see something working with this...
* Empty Object SnowVisualize
* Snow VoxelArray
* Snow Solver (Birth rate .1)
Edited by narthe
  • 2 years later...
* Snow VoxelArray
Can you share a .hip file of this? I can't get it work X_X
  • 3 months later...
Have you successful compile the plugins? If so, make sure put the dll file (on Windows), or dso file (on Linux) into the plugins directory that Houdini realize. Then open Houdini, in a DOP network, hit tab and start to type "snow", you should snow_solver, snow_visualize and snow_voxel_array.
