JuriBryan Posted December 2, 2012 Share Posted December 2, 2012 Hey, I am looking for a way to optimize a scene like the one in the attached file. Mostly I am looking for a way to get rid of the noise on the sphere. I tested the whole thing with Pixel Samples set to 50x50, which I think is kinda crazy , and I still got noise on the sphere plus the render time was over 6minutes for a single frame. Is there a better way to get rid of such noise then pumping up the pixel samples? and is there a better way to make my points emit light? right now I am using a Mantra Surface shader that uses point colour as emission colour and the emission intensity gets multiplied by the opacity, which seams to work but is clearly not the best way to do something like this any Ideas to make this work, I never tried lighting with particles in houdini before and am kinda stuck ever little help would be great! cheers, Juri ParticleLighting.hipnc Quote Link to comment Share on other sites More sharing options...
eetu Posted December 2, 2012 Share Posted December 2, 2012 Looks like you could instance a point light to each particle, that would probably be faster. Especially if you limit the radius of the lights. Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted December 2, 2012 Author Share Posted December 2, 2012 well... that killed my houdini I used a instance object, gave it the point light and inside the instance object I object merged in the particle system. ass soon as I left sop level nothing was moving... any idea why? cheers Quote Link to comment Share on other sites More sharing options...
jujoje Posted December 2, 2012 Share Posted December 2, 2012 Hi, One way to fix the graininess and speed up the renders is to copy spheres onto the particles an use them as a geometry light. This worked pretty nicely. The changes I made to the scene was to mainly to create a geometry light and turn off the 'emission illuminates objects' on the particles. Also turned the sampling down a bit. Much of the graininess seems to come from the depth of field. It might be best to do the DoF in post, as to get a nice look you're going to have turn up the sampling really high (I was getting nice results at 50x50 samples though). It could be worth splitting the scene into a particle pass (and render with the micropolygon renderer for the extreme DOF) and the sphere with you can render with pbr for the lighting with far fewer samples. Generally speaking, I think that using the emission option on the mantra surface shader tends to be really grainy (at least that's been my experience thus far). Never had much luck instancing lights, as to get the light to be the point colour seems to slow down the scene translation significantly. Hoping that eetu or someone could point out how it should be done… geoLight.hipnc Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 2, 2012 Share Posted December 2, 2012 Reflective surfaces togheter with small lights takes a while to get rid of all the noise. My rendertimes are not much better but I changed the scene to be gamma corrected which helps some in dark areas and is more physically correct. I also use a Geometry light instead of emission which I find easier to work with. Render took 1:45 min on my machine. ParticleLighting.hipnc Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted December 2, 2012 Author Share Posted December 2, 2012 hey, thanks everyone! the geolights work way better then the emission over the shader. And jujoje is right, it would be awesome if eetu could point out how it is done! Thanks again for the quick help Cheers, Juri Quote Link to comment Share on other sites More sharing options...
bloomendale Posted December 3, 2012 Share Posted December 3, 2012 Reflective surfaces togheter with small lights takes a while to get rid of all the noise. My rendertimes are not much better but I changed the scene to be gamma corrected which helps some in dark areas and is more physically correct. I also use a Geometry light instead of emission which I find easier to work with. Render took 1:45 min on my machine. Change Tile size back to 16 from 64 and you'll cut render time in half. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 3, 2012 Share Posted December 3, 2012 Change Tile size back to 16 from 64 and you'll cut render time in half. Almost half. Usually use 16 but messed around and forgot to change back. It is however strange that it makes a difference. I have loads of ram so I fail to see how using a bigger bucket size can make things slower when using PBR. When using MP the renders becomes faster using a bigger bucket. Someone please enlighten me. Quote Link to comment Share on other sites More sharing options...
eetu Posted December 3, 2012 Share Posted December 3, 2012 Never had much luck instancing lights, as to get the light to be the point colour seems to slow down the scene translation significantly. Yeah, just tried - it does indeed seem to take an ungodly amount of time. Using a point(,instancepoint(),,) expression on the light color it looks like it's recooking the sop the point() is referring to - again for each instance.. sigh I seem to remember there being a mechanism where point attributes on the object being instanced to would override parameters on the instanced object. Doesn't seem work though, maybe I'm just remembering the material overrides. Wouldn't it be nice, though?.. Anyway, the rendering itself is quite fast this way, and no noise.. juribryan_ParticleLightinge.hipnc Quote Link to comment Share on other sites More sharing options...
bloomendale Posted December 3, 2012 Share Posted December 3, 2012 Almost half. Usually use 16 but messed around and forgot to change back. It is however strange that it makes a difference. I have loads of ram so I fail to see how using a bigger bucket size can make things slower when using PBR. When using MP the renders becomes faster using a bigger bucket. Someone please enlighten me. This image has small difficult area witch renders magnitude slower. So at the end you're using only one core (tile is just too big to "cut" this area to several cores) while others are just idle. Quote Link to comment Share on other sites More sharing options...
