pcopen find farthest point from sampled ones
qbick
afaik pcopen finds closest points to given one.
im need to find the farthest one from found.
for example pcopen finds 10 closest points - from that 10 points i need to get P-attrubite from farthest one.
can someone help me please?
i found point cloud farthest node in vop, but it finds a farthest distance to point - im need to get an P-attribute, not just a distance.
thanks.
Ok so if you can get the point number of the furthest point (do a pc iterate and just take the max distance), then you can do an attribute import with that point number to get the position you're after.
If this doesn't make sense I'll jump into Houdini in a bit and create you a sample scene.
with pcfarthest i can only get distance, not point number.
if its not hard for you - can you build a little example?
Ok I'm on a small laptop with a one button mouse, so that was slightly frustrating! I have to set something up for home use that's not a complete PITA.
This looks like it does what you want though. Returns the point position of the furthest point from the point cloud open node, so mess with your distances/number of points there.
Hope that helps
Christian
furthestPointPos.hipFetching info...
Hope that helps
Christian
thanks for help!
I took a look at the file and went to throw together an alternate method, but the values I was getting did't match yours. It looks like the max vop, when working on vectors, gives you the maximum value in each component, which is causing your pointPos values to be incorrect
An easy way to get the P attribute of the farthest point in your point cloud is to use the Point Cloud Num Found node to get the total number of points returned by pcopen, then subtract 1 from that number and plug it into a Point Cloud Import by Index node.
