awdahz Posted January 27, 2004 Share Posted January 27, 2004 i have 3dsmax5 and i use facialstudio1.5 from di-o-matic i have also polytrans4.1.2 with its plugins to 3dsmax5 i have houdini6 too the problem is : i create a face in max5 with facialstudio1.5 and animate it but i cannt bring this face with its animation data to houdini i try polytrans , 3dexploration , motionbuilder , viewpoint interchange , softimage ... i try everything but i couldnt do it polytrans4.1.2 cannt convert shape animation softimage can import face animation via .xsi file but cannt export it soooo please help me ,thanks Quote Link to comment Share on other sites More sharing options...
michael Posted January 27, 2004 Share Posted January 27, 2004 does max offer a way to export a series of obj's? is so, you could then just read them into a file sop hth Quote Link to comment Share on other sites More sharing options...
awdahz Posted January 28, 2004 Author Share Posted January 28, 2004 max does not support OBJ(s) files i try to do that but it does not work Famous3d support OBJ(s) files but when i tranfer the face from facialstudio1.5 to famous3d2.5 it lost the animation !!! can anyone help thanx Quote Link to comment Share on other sites More sharing options...
stevenong Posted January 28, 2004 Share Posted January 28, 2004 Hi there, Try searching on the net to see if there's a OBJ export plugin for max. Or you can export DXF instead. Also, please look at the Formats.pmk.pdf file for a list of formats Houdini supports. Cheers! steven Quote Link to comment Share on other sites More sharing options...
awdahz Posted January 28, 2004 Author Share Posted January 28, 2004 i can import .obj and .dxf to houdini also i can export .obj from 3dmax via polytrans but how to export from 3dmax as .OBJ files ( fame1.obj , frame2.obj , frmae3.obj , ...) i think it is clear now pleeeeeeeeeeaaaaaaaaaaase hellllllllllllllllppppppppppp Quote Link to comment Share on other sites More sharing options...
michael Posted January 28, 2004 Share Posted January 28, 2004 max does support obj....look on the net for some plugins for importing and exporting them... Quote Link to comment Share on other sites More sharing options...
Mcronin Posted January 28, 2004 Share Posted January 28, 2004 You need a plugin to export OBJs from Max, there are a bunch of free ones on the net. Also, there is a way to bake you animation into a series of OBJs, it's a feature of Max. Unfortunately I haven't used Max in a couple years and I can't remeber the name of the tool. Quote Link to comment Share on other sites More sharing options...
awdahz Posted January 28, 2004 Author Share Posted January 28, 2004 please try to remember it please do something and remember it please Quote Link to comment Share on other sites More sharing options...
meshsmooth Posted January 28, 2004 Share Posted January 28, 2004 To generate an object for each frame just use the snapshot tool and specify it to go over multiple frames. Or even make a max script macro to snapshot and export the face at the current frame and step through each frame. The second may be easer because if you want to have an object in a separate file this may be easer. If a file with all the faces in the one file is ok snapshot tool is your friend. If you cant find the snapshot tool just search help for it. Quote Link to comment Share on other sites More sharing options...
michael Posted January 29, 2004 Share Posted January 29, 2004 http://www.dreamsandmagic.com/p_max.htm http://www.cadalyst.net/extras/plugins/Import.html etc Quote Link to comment Share on other sites More sharing options...
meshsmooth Posted January 29, 2004 Share Posted January 29, 2004 ....http://www.maxplugins.de/ ect.... Quote Link to comment Share on other sites More sharing options...
awdahz Posted January 29, 2004 Author Share Posted January 29, 2004 hi guys finally i import it as .obj(s) files into houdini but i have another prpblem every .obj file in houdini is not one object and consist of many polygons how can i make it consist of one object that have many polygons in it ...i mean one primitive(many polygons inside it ) help thanks Quote Link to comment Share on other sites More sharing options...
bfx Posted January 30, 2004 Share Posted January 30, 2004 Hi here you will find a 3dsmax script to export polygons with uv (or not) to houdini. It create padded houdini geo file. With max compound object you will have to add an editMesh before to export. If not you may not be able to pick the object. Let me know if you use it thanks francois b.fx@free.Fr maxpoly2houdini_beta1.00.zip Quote Link to comment Share on other sites More sharing options...
