Sweep with closed cap?
poppy
the first reverse is just to correct input normals since they point inwards
divide with unshared edges creates polygons from all border edges of your geometry, sort of like caps
but such caps have normals always pointing in opposite direction as your geometry so you need to reverse them
then merge and fuse
  • 4 weeks later...
then merge and fuse
Can't you use polycap like this?
http://screencast.com/t/NWhmyug8om
The key to working with polycap is you need to select the edges first. You can also select all the edges and poly cap them all at once.
I will say Anim's workflow is better, but doesn't polycap also work the way I outlined it?
Edited by pixate
