Flip particles disappearing after collision
WesleyE
Hi everyone,
I'm looking to build a simple glass fill animation but I've stumbled onto a problem before I could even begin the animation.
I'm using a flip fluid that has some initial data from a SOP object. I've also made a glass that I want the flip fluid to collide with. I had some problems generating a valid SDF for the collision, but I have seemed to solve that by adjusting the offset on the isooffset node.
If I feed the generated collision SDF to the flip solver, the particles start to behave in a weird way. They seem to remove themselves from the sim when they touch the glass. I've added an image demonstrating the problem in 3 frames and is also showing the collision geometry.
Can anyone point me to the reason why the particles are disappearing?
Thanks
post-7460-0-71366400-1357347645_thumb.jp
Glass.hipnc
The collision sdf for your object maybe be of fine resolution but the actual collision field of the flip object probably isnt. There's a parameter for collision field resolution which you should enable enforce a higher resolution of the collision field so it can sample your glass sdf better.
Also what fabiano said, that will make things much easier.
  • 3 years later...
Hi... I ´ve already have a collider really extruded and big... But the particles still dissapear... for no reason.. They are inside the BBOX so... Any help will be appreciated!
Thank you very much in advance!
