Doum Posted January 15, 2013 Share Posted January 15, 2013 Hello, I'm a newby with houdini and I'm trying to play with Vopsop displace along normal. I want to play with the patterns nodes, but it seems that they need uv coordinates. I my SOP network I have a grid, uv project and the vopsop node. How can I access the uv coord inside the vopsop and plug them in the input of the wanted patterns? Maybe that not the way it is supposed to work? I hope it is clear enough, I'm not really used to all these houdini terms. Thx Doum Quote Link to comment Share on other sites More sharing options...
Annon Posted January 15, 2013 Share Posted January 15, 2013 Just use the x and z pos values if its a grid using the vector to float node. Otherwise can't you just use the UV coords from globaLs? Quote Link to comment Share on other sites More sharing options...
Doum Posted January 15, 2013 Author Share Posted January 15, 2013 Just use the x and z pos values if its a grid using the vector to float node. Otherwise can't you just use the UV coords from globaLs? That exactly what I want to use, the UV coord from the globals, but I only see the point W coordinate. How can I access the other coordinates? Quote Link to comment Share on other sites More sharing options...
zarti Posted January 15, 2013 Share Posted January 15, 2013 hi Doum , see the attached file .. -- uv_in_vops.hipnc -- .cheers Quote Link to comment Share on other sites More sharing options...
Doum Posted January 15, 2013 Author Share Posted January 15, 2013 hi Doum , see the attached file .. -- uv_in_vops.hipnc -- .cheers Thx zarti, I'm in the bus back to home, but I'll check it tomorrow when I'll arrive at work. Quote Link to comment Share on other sites More sharing options...
Annon Posted January 15, 2013 Share Posted January 15, 2013 Sorry in not in front of a computer at the moment, but try an import attribute, set it to UV, vector and vector to float etc. If your UVs are vertex attributes, attribute promote them to point attributes before hand... Quote Link to comment Share on other sites More sharing options...
Annon Posted January 15, 2013 Share Posted January 15, 2013 Lower case uv, bloody predictive text!!! Quote Link to comment Share on other sites More sharing options...
Doum Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks guys, the node (import attribute) seem to be really useful . I'm curious about the use of Facet node in your tree Zarti, what the purpose of that node? Is it there for future use? Quote Link to comment Share on other sites More sharing options...
Annon Posted January 16, 2013 Share Posted January 16, 2013 The facet node was probably used to generate normals. Quote Link to comment Share on other sites More sharing options...
Doum Posted January 16, 2013 Author Share Posted January 16, 2013 The facet node was probably used to generate normals. Thx Christian You really seem to have a nice community around houdini software... I'm a XSI user for about 6 years now doing ICE since 3 years and I'm trying to learn houdini. I think the thinking of this community will help me a lot Quote Link to comment Share on other sites More sharing options...
