danylyon Posted January 27, 2013 Share Posted January 27, 2013 Hi I have a SOP solver in which I assign values to the Color (Cd) to Points. (with the Point SOP) Outside of that context, they seem to be gone. How can I keep / export / import them? Quote Link to comment Share on other sites More sharing options...
anim Posted January 27, 2013 Share Posted January 27, 2013 not sure that this is the case but make sure that on your dopimport you set Import Style to Fetch Geometry ... instead of Transform ... or post the file so we can explore Quote Link to comment Share on other sites More sharing options...
danylyon Posted January 27, 2013 Author Share Posted January 27, 2013 It's already set the "fetch geometry.." Here's the file. in jelly there's the geometry of the jellyfish and the dop import. in DOP jelly, theres the dynamic network. It's basically a geometry, deformed by a sop and simulated by a wiresolver. (with multisolver) Inside the sopsolver, I define colors (last point sop).. Would be great if you could have a look. jellyfish.hip Quote Link to comment Share on other sites More sharing options...
mawi Posted January 27, 2013 Share Posted January 27, 2013 (edited) The SOP-solver applies to the RestGeometry data and your dopimport imports Geometry data. Edit. What are you trying to do with that sop-solver? Edited January 27, 2013 by mawi Quote Link to comment Share on other sites More sharing options...
danylyon Posted January 28, 2013 Author Share Posted January 28, 2013 Ok that makes sense now. The sop solver is deforming the geometry (with a soft transform) and giving it an external force.. so the jelly moves. I actually ended up using the velocity vectors to color the jellys.. looks cool for this. Thanks for clearing it up. Quote Link to comment Share on other sites More sharing options...
