dolexd Posted January 31, 2013 Share Posted January 31, 2013 Hi Everyone, Can someone tell me the exact meaning of the Range field. I mean, under flames tab, there is a Cooling Field Rand and under shape and dissipation there is control Range. How do we know what range to set and what happens when I set a range from 0 to 2 thanks, sid Quote Link to comment Share on other sites More sharing options...
anim Posted January 31, 2013 Share Posted January 31, 2013 the ramp parameters expect their input to be in range 0-1 so the Control Field needs to be first remapped from some range to 0-1 and Control Range parameter defines that source range so in case of 0-2 it means that if the source sample has value 0 result will be value from start of the ramp if 2 from end of the ramp, any values between 0-2 will result in corresponding value from the ramp curve. Extremes are clamped. Quote Link to comment Share on other sites More sharing options...
