bloomendale Posted March 5, 2013 Share Posted March 5, 2013 Here is short exercise i've done in Houdini after watching similair video on vimeo. https://vimeo.com/61090296 Spent weekend on this - hope you'll like it) 2 Quote Link to comment Share on other sites More sharing options...
freaq Posted March 6, 2013 Share Posted March 6, 2013 that is pretty impressive for a weekend's work. very nice Quote Link to comment Share on other sites More sharing options...
Aaron_ Posted March 7, 2013 Share Posted March 7, 2013 wow that was cool. great job. can you share to us how you did that? Quote Link to comment Share on other sites More sharing options...
AdamJ Posted March 7, 2013 Share Posted March 7, 2013 cool! Quote Link to comment Share on other sites More sharing options...
bloomendale Posted March 8, 2013 Author Share Posted March 8, 2013 Thanks guys. Since i'm interested in point rendering i did the whole planet (with jupiter texture actually=) with points (4mln), implemented swirl behavior in vops (sum of different velocities to get the swirl form i need), cache active/passive parts separately. Then filtered active points by velocity, pos etc to get fraction of them as source for pyro sims. Did several pyros for shockwave and swirl to enhance it a bit. Ah, and added emission pass to color inside of the swirl by ramp (didn't like the alternative with light lightening up the same area, so went with emission). Added small debris/points (but vimeo's compression destroyed 80%). + a bit of comp. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted March 8, 2013 Share Posted March 8, 2013 isn´t the whole thing as points a bit of an overkill? what were your rendering times? Why didn´t you converted to points just the area to be uh...über-atomically-implosionated? Quote Link to comment Share on other sites More sharing options...
dobin Posted March 8, 2013 Share Posted March 8, 2013 pretty cool...I did something similar before using the same technique: https://vimeo.com/61345372 Quote Link to comment Share on other sites More sharing options...
bloomendale Posted March 9, 2013 Author Share Posted March 9, 2013 (edited) isn´t the whole thing as points a bit of an overkill? what were your rendering times? Why didn´t you converted to points just the area to be uh...über-atomically-implosionated? Yeah, as i stated earlier it wasn't necessary. I actually have separate caches for active part (~1/4 of all points) and just one frame cached out of the rest. I had some not the best rendering times with points so decided i can spent a couple of days trying it again) dobin, really cool looking collapse. Liked the noise edge of destroying area. Tried initially something like yours but decided to go more gaseous way) p.s EDIT: Lied) about 1 min/frame for 4 mln points (3930k@4.2, 32gb), not ~20 sec. Edited March 10, 2013 by bloomendale Quote Link to comment Share on other sites More sharing options...
