kgoossens Posted March 13, 2013 Share Posted March 13, 2013 Hi, Is it possible to control the radio buttons of an existing node using an expression? For example: switching between the Divisions and Breakpoints folder of the Carve node. I thought of adding an expression by right clicking the radio buttons but this gives you a drop down list of the folders. Right now I have to duplicate the nodes and control them using a switch node. Cheers, Quote Link to comment Share on other sites More sharing options...
merlino Posted November 24, 2015 Share Posted November 24, 2015 Hi, I have the (almost) same question. I'm creating a HDA and I'm using a "Volume" SOP node. It already have what I need: the switch between "Center/size" and "From Camera", what I can't find is how to drive it with as it was exported to Type Properties. I can create a switch between two Volume sops but that's not the idea ... even if it will works. Cheers! Marco Quote Link to comment Share on other sites More sharing options...
