Using texture for dynamic extrusion
misterbil
I looked around for a while about this. But can't seem to figure this out.
my my goal:
-I'm trying to have a geometry extrude based on a monochromatic textures.
-then animate the texture (uv scrolling or procedural) and have the extrusion follow.
This guy did a fantastic job of what I'm trying to do:
example:
from Manuel Tausch on vimeo :https://vimeo.com/8309528
post-7368-0-22484000-1365513911_thumb.jp
I think I have the extrusion part. Right now it's on a grid and don't look the way I want on a sphere but I'll try to figure that out later.
My main issue is that my animated texture... well, don't animate.
here is the texture I'm using:
I know it doesn't tile but it's just for testing.
I have a cop network (where I do the animation) in my sop and I call that in my extrusion.
any help would be greatly appreciate.
thanks.
bil
procedural_extrusion.hipnc
Hey Bil,
I've changed your file a little bit. That's how I would do it. I know I used more nodes, but I like the flexibility of VOPS. Not sure if its faster or slower.
The important part to note here is the op syntax which is as follows:
op:/img/comp1/OUT[$F][/CODE]
Credit goes to Macha from this thread:
http://forums.odforc...e-on-an-object/
Adding [$F] ensures proper updates of the texture.
-dennis
Edited by dennis.weil
Thanks Dennis,
but I get the same problem that the other guy in the threat had... adding the [$F] doesn't seems to work for me :(
Did it work for you? did the extrusion get animated?
after adding the [$F] the expression seems to error out...
my string look like that:
op:/obj/sphere_object/cop2net1/MAP_OUT[$F]
wondering if I'll have to bake the texture as well. :(
bil
putting [$F] after op:path forces houdini to cache the images per frame. so, if you change something in cops you won´t see any updates in the viewport since the sequence is already cached. you have to use texcache -c or override the numbers of images which should be stored with texcache -n.
or you could use a callback that clears the cache always at frame 1.
petz
procedural_extrusion1.hipnc
