Copy Sop Orientations
fex
Hi all,
nice to see Odforce being online again :)
anyone knows how to get copies rotated evenly on source
object ... what i tried is stamping $PT but the point numbers
are not right sorted for this task.
Any ideas on this or totally different solutions?
thx fex
Hi fex,
Try experimenting with adding an Up Vector attribute (or a Velocity) attribute to your template. A rotation is much more fully defined if you have two vectors to describe it.
Try this first: Up Vector = {0,0,-1} (down z-axis)
Maybe that will help?
while we are on this subject... how can i control this when using point instancing..
for example.. i have a tube going in the zed and i am copying that using a poly sphere as the template.. if i use copy sop, it looks fine.. looks like the tube is coming out of the sphere along the point normals which is good.. but if i go and try to do it with point instancing instead of the copy sop (same sphere and tube), all the tubes will be aligned going in the direction that i set..
how can i use point instancing and keep my obj rotated correctly to the point normals of the templace geometry?
thanks,
dave
