magneto Posted April 18, 2013 Share Posted April 18, 2013 Hi, I have an open polygon where I want to break off each edge into a separate polygon. I tried the facet sop, fuse sop (unique tab), but they didn't do anything. The order of the points are random, and I have multiple polygons that are like this that I need to break off into separate polygons at once. So something like this: I was hoping this would be done without using the foreach sop. But all ideas are welcome. Thanks Quote Link to comment Share on other sites More sharing options...
3__ Posted April 18, 2013 Share Posted April 18, 2013 try curvesect, connect to both inputs. Quote Link to comment Share on other sites More sharing options...
magneto Posted April 18, 2013 Author Share Posted April 18, 2013 Never mind Carve sop for 0 to 1 with Cut At all Internal U Breakpoints works great. Didn't realize it would do that Quote Link to comment Share on other sites More sharing options...
magneto Posted April 18, 2013 Author Share Posted April 18, 2013 Thanks Craig I tried what you said but it didn't split each edge, although the number of polygons increased a little but not the right number. Quote Link to comment Share on other sites More sharing options...
sam.h Posted April 18, 2013 Share Posted April 18, 2013 Never mind Carve sop for 0 to 1 with Cut At all Internal U Breakpoints works great. Didn't realize it would do that Thanks, that is good to know! 1 Quote Link to comment Share on other sites More sharing options...
boby Posted June 20, 2014 Share Posted June 20, 2014 Hi ! I bump this thread cause i'm having an issue using this technique. Strangly, some points are randomly not split as expected, can someone help? See file linked Thanks question_carve.hipnc Quote Link to comment Share on other sites More sharing options...
old school Posted June 23, 2014 Share Posted June 23, 2014 Please submit the bug along with the file. Copy/Paste/append a second carve SOP placed after the first catches that last primitive as a work-around. 1 Quote Link to comment Share on other sites More sharing options...
boby Posted June 24, 2014 Share Posted June 24, 2014 Hi old school ! Do you mean report a bug to SESI? As i just begin using houdini, i'm not sure sure that's a bug, but more a user issue Did you check the hip? Thanks ! Quote Link to comment Share on other sites More sharing options...
old school Posted June 25, 2014 Share Posted June 25, 2014 It is a bug. I opened the file and replicated the issue. Appended a second Carve SOP and it got it. Yes submit the bug in to Side Effects. One of the primitives contains three points coming out of the Carve SOP. Applying a second Carve SOP splits this primitive correctly. If you haven't submitted a bug before, now's a good time to do it. Remember to attach the hip file to the bug as it may be specific to the geometry. Quote Link to comment Share on other sites More sharing options...
