misterbil 2 Posted May 17, 2013 (edited) Hi All, I'm trying to do 2 things but I think they are about the same. 1) trying to subdivide or better copy a bunch of cubes to form the following pattern: I would like then to turn it into a glue rdb afterward. But first I need to get to this.. I tried to follow 2 different tutorials, Peter Quin discovery title sequence and SideFX own lego type boxelizer. But I think I need to get an hybrid between the 2. I think that my problem is that I need to group each copy and use it as new boundary or something like that. 2) Based on the same idea, I would like to try to get the cube to be divided like this (here is a sliced view). And again I would like to turn it into an rdb object later on. I attached my first attempt. I'm trying first to apply a random color to each primitive, but for whatever reason, it's applied to each faces... not the entire cube... I know I'm doing something wrong. There are 2 "primitive" SOP in the scene, they are doing the same thing, I was just trying to see if I could color them using the stamp expression (before the copy SOP), or after... Any help, suggestion, comment, ihint or random string of words woul dbe greatly appreciate. Thanks. bil random_cubeDivision.hipnc Edited May 17, 2013 by misterbil Share this post Link to post Share on other sites
0rr 17 Posted May 18, 2013 this is a mere sketch of what you could do. I am not sure maybe it'll help. cubediv.hipnc 1 Share this post Link to post Share on other sites
Guest tar Posted May 18, 2013 an option Boxes_6.hipnc Share this post Link to post Share on other sites
misterbil 2 Posted May 19, 2013 Thanks a lot guys, Orr, very interesting set up I'll dig in it a little more tomorrow. Marty, this set up look very robust and I like the simplicity of it. Beautiful! Thanks for adding the random colors and the rdb. Based on these I'll try the distance based one. houdini for the win! bil Share this post Link to post Share on other sites
misterbil 2 Posted May 20, 2013 thanks again for your reply gentelmen, I finally got the time to look into both scenes in more details. Orr, I got confused a little by your scene as you kind of have two different network at sop level, doing the same thing but differently. Very interesting though (As is your work by the way, impressive stuff), you also used some function that I hadn't heard of before. the "detail" function ... I couldn't figure out what it really does? by the way should I used one network instead of the other? But your set up is very well build for OTL, very technical too. Marty, again thank you so much for making it so clear and colorful. I also learned a lot about new nodes, "assemble", "match size" and "vertex". all very easy to understand for a noob like me thanks Share this post Link to post Share on other sites
Guest mantragora Posted May 20, 2013 (edited) the "detail" function ... I couldn't figure out what it really does? Alt+Shift+T and write: exhelp detail Enter. Get yourself familiar with using textport or with http://www.sidefx.co...houdini12.5/expressions/ EDIT: Something is broken with links because it breaks them when I'm trying to attach them. Just Ctrl+C/Ctrl+V the whole link address yourself. Edited May 20, 2013 by mantragora Share this post Link to post Share on other sites
misterbil 2 Posted May 21, 2013 thanks Mantragora, Yes I do need to get more familiar with Houdini expressions. But I was more looking for a simple explanation, more like plain english. I guess I'll figure it out one day. Share this post Link to post Share on other sites
misterbil 2 Posted May 29, 2013 Here are two test that I'm working on but can't seem to get working. I based my tests from Orr example as it allowed me more random/procedural approach. -the first one is just trying to get the cubes to fall apart randomly. I'm deleting the glue bound using a bunch of point (from a points to volume sop ). My problem is that my glue bound don't stay deleted! -the second one is trying to set the division based on distance. I'm using a bounding box to set up the area of division. any help with a bit of explanation would be greatly appreciated. thanks b random_cubeDivision_glue.hipnc distance_cubeDivision.hipnc Share this post Link to post Share on other sites
Oidy 0 Posted April 7 I know this is a super old post but is there any way someone can update these examples so that I can see them in H17? Or even point me to something more current? Share this post Link to post Share on other sites
misterbil 2 Posted April 7 Hi Oidy, You should be able to open them in H17 as I was able to open them up in H18.5. cheers Share this post Link to post Share on other sites
