Cvex instead of polywire
Hi everyone,
I was wondering if it is possible to "polywire" a set of curves at render time using cvex.
I tried to use the fur procedural shader, I have a simple cvex shader for the guides, with just a parameter for width.
And it renders nothing.
Do I have to fill in every parameters of the fur procedural ? ( i am pretty sure it's not a good approach ... )
Or is there a simpler set up to do that ?
Thanks symek ^^ good infos there.
So , as far as I understand, I would need to build a plugin running some cvex code, to be able to get my wires a render time ?
I guess HDK would be involved in that case ? :wacko:
