substep Posted May 18, 2013 Share Posted May 18, 2013 Hi, sorry if this is silly question. but how can I create a point group based on UV's? I can see I have Uv's in the details view, and I'd like to group the points whose UV value U == 1 or V ==1. it seems simple enough, but i'm unable to figure it out. Thanks! Or is there a better way to group outside points? Quote Link to comment Share on other sites More sharing options...
Ronald Posted May 18, 2013 Share Posted May 18, 2013 (edited) Hi, you can always use expression to create group. Hope it helps. groupByUV.hipFetching info... Edited May 18, 2013 by Ronald Quote Link to comment Share on other sites More sharing options...
bloomendale Posted May 18, 2013 Share Posted May 18, 2013 (edited) use "Group by expression" mode in Group SOP with something like point(opinputpath(".",0), $PT, "uv", 0) == 1 && point(opinputpath(".",0), $PT, "uv", 1) == 1 or the same using local vars.. Edited May 18, 2013 by bloomendale Quote Link to comment Share on other sites More sharing options...
substep Posted May 18, 2013 Author Share Posted May 18, 2013 ahh this works for me now, I was missing the attribute create sop, which was creating a uv attribute? I thought I already had a UV attribute from the UV texture sop. I can see in details, it changes from uv[0] etc, to uv[x]. please forgive my ignorance, but could you explain this a bit please? Quote Link to comment Share on other sites More sharing options...
bloomendale Posted May 18, 2013 Share Posted May 18, 2013 to use local variables ($***) you have to create them. Bunch of nodes creates attribs but not the local vars. So you need to add attrib create sop to create them. uv[x] is a component of a vector attrib while uv[1] - component of the 3-float attrib. while it seems the same vector attribs will be transformed with your geometry (transform sop etc) but 3-floats won't. Quote Link to comment Share on other sites More sharing options...
substep Posted May 18, 2013 Author Share Posted May 18, 2013 ok, that makes sense. I was under the impression it created the variable automatically. not that it matters, but to help me understand, is there any reason some nodes do, and some don't create the variable? I guess that's what I'm seeing in the 'detail' pane of the details view, right? Your expression was much more clever than mine. I used $UVX == 1 || $UVX == -1 || $UVY == 1 || $UVY == -1 lmao thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
anim Posted May 18, 2013 Share Posted May 18, 2013 you don't have to create uvs with attrib create just access them using $MAPU and $MAPV which Group SOP maps automatically to current uvs Quote Link to comment Share on other sites More sharing options...
