TheAdmira1 Posted May 23, 2013 Share Posted May 23, 2013 Hello all, So I'm building a "shot launcher' for my studio in Python. The tool pops up a GUI, asks the artist for show, seq, shot, application, the plate, and some other info for naming and padding. The tool then builds a name for the file, reads in a template, edits necessary info, writes out the new file, and finally opens the file within the selected program. This works great for Nuke, Maya, AE, and Syntheyes. However, when I edit the Ascii file for Houdini and then open it, I get an "Invalid .hip Header" warning, and the file fails to load. I have gone through the file created, and the template it was sourced from. The formatting all seems to be correct, but I notice that there are a ton of what I assume are generated sequences from when the template file was saved. Is there a way to make editing and launching an Ascii file for Houdini work? Are the numbers/sequences I see throughout the file generated only for the original filename and destination? Any help is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
edward Posted May 23, 2013 Share Posted May 23, 2013 .hip files are not pure ASCII. They are actually ASCII "packets" within a cpio format file. There are some provided command line tools to expand and collapse .hip files if you want to do some very low-level surgery. Personally, I would just load up hython with your .hip file, do whatever operation you want and then save it back out again. Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted May 23, 2013 Author Share Posted May 23, 2013 Thanks Edward! I will try that today. Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted May 24, 2013 Author Share Posted May 24, 2013 Is there a location online to see all of the modules present in Hython? I can find everything for the hou module just fine, but things like objecttoolutils and such are not documented on SideFX's site as far as I can tell. Sadly I do not have el googs at work I can pull them up via the interactive help in the commandline, but I was hoping for something a bit easier to parse and move around in. TIA! Quote Link to comment Share on other sites More sharing options...
graham Posted May 24, 2013 Share Posted May 24, 2013 Sadly there is no proper documentation for these modules. I would suggest filing an RFE with SESI to provide automatic documention similar to Sphinx or the HDK docs for all their custom Python modules. I've got one in there somewhere. Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted May 24, 2013 Author Share Posted May 24, 2013 Thanks Graham, just saved me a few hours of searching haha I definitely will put in an RFE this afternoon. When you say you have one in there, do you mean module or RFE? Quote Link to comment Share on other sites More sharing options...
graham Posted May 24, 2013 Share Posted May 24, 2013 An RFE. Don't remember the number though. Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted May 24, 2013 Author Share Posted May 24, 2013 no worries, ill have a look. thanks for the heads up Quote Link to comment Share on other sites More sharing options...
