command line cache .sim
I know what you mean, but this is just to quickly get an alembic file into maya, and still have the .sim on hand to cache everything out later. it probably seems strange ;), and I can do it from within houdini obviously, But I wanted to compare sim times through command I suppose and have that available to me.
Edited by substep
ok wait, no. lol. $ST doesn't seem to work either. I can see it trying to write the file without the variable, replacing it with every frame. It does however work when I turn on "explicit cache" on the dopnet. But then it's wasting time writing both files, deleting one, writing both files, deleting one, etc, etc
Edited by substep
this kinda works, as the dynamics ROP accepts $FF as a variable, but it's not saving the substeps. It's frame for frame. If you look at how the DOPnet saves substepped .sim files - if you have 4 substeps, then frame one will have 4 .sim files named <filename>_1, _2, _3, _4. since it's using $ST.
I'm still somewhat green to all this, so I obviously really don't understand, but could someone clear up why a "Dynamics" ROP that saves out .sim files won't save substeps?
I suppose I could set my substeps to 1, and my simscale to .25. save out 4x as many frames, then read that back into a dopnet set to 4 substeps, and 1 sim scale...?
maybe there's a better way?
If I tag a file node onto the end of my network inside my DOPnet, can I cook that from the command line somehow?
Edited by substep
Guest mantragora
Kids, kids. Do I really have to fix everything for you ;)
Append fileDOP at the end of you sim network, set it to "Write" and use "$ST.sim" in it. And then add dynamics ROP in OUT and remember to turn on "Initialize Simulation OPs". Set its path to something that doesn't overwrite the name of fileDOP path (don't even use $F in it, let it write to the same file in each frame, call it "forceCook.sim" or something like that). Now try to call your ROP. It should force the network to cook and with it the fileDOP to write each substep.
Edited by mantragora
haha, thanks! is this not still writing two .sim files to disk though?
I just gave it a shot, and I get the same results as I did just turning on explicit cache on the dopnet, and letting the dynamics ROP error out writing over the same file since $SF didn't work in the dynamics ROP. So it still seems to be writing two .sim files to disk at once. if you stop the sim while the temp .sim file is being written, it's still the same file size as the wanted .sim files with or without $SF in the filename.
please correct me if I've misunderstood ;)
it seems nice being able to run 4 bullet sims from the command line though, processors are maxed, and no gui. I guess we'll see how this goes.
Edited by substep
Guest mantragora
So set your ROP path to reference path parm of the fileDOP and set fileDOp to "No Operation", than ROP will save correctly and you will get one file saved only by it at a substep.
I was really hoping this was gonna work. But the "render" never starts, it just hangs. I did notice though when referencing the path of the file dop into the dynamics rop, that it didnt turn green. maybe it doesn't accept reference?
edit: actually, it started after about 3 minutes. but it's only writing every odd frame. hmmm ? I believe I have two substeps on this sim.
I did notice though, that by using the file dop, or explicit cache on the dopnet, and writing over the same file in the dynamics rop, it only writes the temp .sim file every frame, not every substep. So I guess that's a little better than what I originally thought.
Edited by substep
Guest mantragora
As long as it works color doesn't matter. So does it work for you or do I have to attach example file?
In my previous message I accidentally used $SF in fileDOP and that's why I though that it stopped working :). After setting fileDOP to $ST, ROP again started to save the correct files again.
Yes, and example would be nice. As $SF in the file dop referenced into the dynamics rop only writes odd frames (1, 3, 5, etc), and using $ST in the file dop referenced into the dynamics rop gives me horribly misnumbered .sim files. I can only assume I'm doing something wrong, but everything your saying is clear as day to me.
