flip fluid surface tension
whodini
I've been playing with flip fluid for a bit now and the one thing I can't seem to figure out is how to enable surface tension in the simulation. Adjusting the surface tension of a liquid is something I do pretty often or have the need to change (when I'm working in naiad or realflow). In houdini I thought it would be an easy setting to find, either set on the flip object or set on the solver but I doesn't seem to exist? Has anyone ever been able to simulate surface tension with flip?
