BulletSOP 2.0.8
MilanSuk
BulletSOP 2.0 - Introduction: https://vimeo.com/67030933
BulletSOP is implementation of Bullet library (bulletphysics.org) inside SideFx Houdini (sidefx.com). It's a plugin for creating incredibly large rigid body simulations on average PC.
At this moment it's single-thread application (we're waiting for official release of Bullet Library 3.0 with GPU support) but speed is very impressive already. As well as memory footprint. The plugin is free! So you can create truly stunning massive simulations.
It has 6 extraordinary nodes which are very powerful and universal. All data which these nodes generate can be modified with standard Houdini nodes.
This tool is compiled for Houdini production builds. It includes many example scenes (beginner -> professional) which are probably the best learning resources. Free video tutorials are coming soon!
Create freely, simulate quickly and enjoy fully!
Main features:
- Bullet RBD Solver
- Support for multiple Broadphases, Constraints Solvers
- Loading data from previous frame
- Geometry decomposition (Tetrahedra, Voxels)
- Static/Animation body
- Convex Hull
- Compound Hull
- Deform static Hull
- Primitive Hulls
- Constraints (auto-generating, spring, 6DoF)
- Collisions Groups
- Object Forces
- Point Radius Forces
- Delete Duplicity data
- Instancing
- Includes many example scenes for studying
- Support for Windows(64bit) and Linux(64bit)
Links:
Houdini: http://www.sidefx.com/
LinkedIn group: http://www.linkedin....Houdini-4796605
BulletSOP 2.0 beta Sneak Peek: https://vimeo.com/57193837
More author videos: https://vimeo.com/user3251535
Best wishes
Milan Suk
PS: You need Houdini 12.5.376 build! With older or later versions I can't guarantee functionality!
BulletSOP_2_0_8__houdini_12_5_376.tar
BulletSOP_2_0_8__houdini_12_5_376.zip
Edited by MilanSuk
  • Like 2
This is WorkInProgress of trailer for BulletSOP.
Of course, We will share scene file ;)
Some statistics:
Pre-fracturing: 35minutes :(
Objects: 48 158
Constraints: 718 838
HighPoly scene: 938 085 polygons
100frames: 1h 2m(1frame - 10s, 100frame: 2m 20s)
wip_bridge_1.mov
wip_bridge_2.mov
Edited by MilanSuk
thanks again, Milan!
Don´t you think it would be a good idea to include a version text file for us to know what´s new on each release?
This version doesn't include any new features. There are speed improvements, fixed bugs and few new scenes.
But yeaah, I can add some text file with list :)
Thank you so much Milan , you are a great guy
Thanks!
For upcoming 2.0.9 version, I changed force GUI(parameters), which is cleaner and more universal. I added really cool new example scene with magnets too.
There are few speed improvements and few new parameters, which speed up your work and let your network(s) cleaner.
Thanks!
Ah thats very nice, you are realy pushing stuff with your bullet plugin.
Some reference:
Digital Domain - 2012 part01
2012 - VFX Earthquake LA
Edited by CeeGee
Sorry for a delay with 2.0.9 version, but I have bad news. It probably takes one more week before public release :(
We are working on new feature - Emitting system(If some objects break, You can emit(particles, smokes, ...) from "share" polygons between objects :)
This is changes file for 2.0.9 at this moment:
* Changed: Force(s) GUI and attributes
* Added: Example Magnet scene
* Improved: updateConstraints()
* Added: "Static" parameter to btBuild RBDs tab
* Added: "Update every frame" parameter to btBuild RBDs tab
* Added: auto-update mass of compound object from child(s) mass
* Added: Example Voronoi compound(cluster) scene
* Added: New node "btExtraCells" which optimalize creating high&low poly pieces
* Fixed: Problem when Houdini cook SOP_Loader node more than one on same frame
* Fixed: Crash when Constraint includes "index of object" which doesn't exist
Edited by MilanSuk
  • 4 weeks later...
  • 2 weeks later...
I'm just posting email to testers with final 2.0.9 version. If all goes well, I will release this version on Tuesday maybe Wednesday. It's for the latest production build - 12.5.469.
This release will include one very exciting news! Stay tuned.
EDIT:
Changes:
* Fixed: Problem when Houdini cook SOP_Loader node more than once on same frame
* Added: "Ground Plane" option(animated) on btSolver Node
* Changed: Rename "Geometry" => "Shapes"
* Changed: Rename "Properties" => "Physics Properties"
* Added: Emitting system
Edited by MilanSuk
  • 9 months later...
I have a lot of error when i try to open the sample scene with H13.
I use Houdini FX 13.0.401 and BulletSOP_2_0_12.
any idea?
and thanx for your work
It's compiled for 13.0.376 so maybe this is problem :wacko:
Edited by MilanSuk
