pxlfx Posted June 15, 2013 Share Posted June 15, 2013 Hey Guys I'm having problems with giving two boxes, with a chain in the middle of them, the same characteristics as a train derailment. A object it hitting the train from the side, so all objects need to interact with one another. Attached is a simple file, if anyone one could help I would really appreciate it. Thanks Guys For_Od_Force.hipnc Quote Link to comment Share on other sites More sharing options...
mangi Posted June 15, 2013 Share Posted June 15, 2013 (edited) Hemanth Here is the Dynamic method you could use . Each Wagon should be a RBD & use a rbdhingeconstraint between each wagon. Check out this really simple, Dynamic Hip file out okay. Mangi trainderailed.hipnc Edited June 15, 2013 by mangi Quote Link to comment Share on other sites More sharing options...
pxlfx Posted June 15, 2013 Author Share Posted June 15, 2013 Hi Mangi Thanks for your help i didn't realise a rbd hindge constraint existed. Thanks again Hemanth Quote Link to comment Share on other sites More sharing options...
pxlfx Posted June 16, 2013 Author Share Posted June 16, 2013 Hi Mangi, I was just wondering if you knew why RBD Fracture object don't seem to work with the RBD Hinge Constraint? I'm trying to pre fracture one of the boxes so when a sphere hits it the object it breaks apart whilst moving. Any ideas Thanks for your help Quote Link to comment Share on other sites More sharing options...
mangi Posted June 16, 2013 Share Posted June 16, 2013 (edited) Can you upload the hip Edited June 16, 2013 by mangi Quote Link to comment Share on other sites More sharing options...
pxlfx Posted June 16, 2013 Author Share Posted June 16, 2013 No problems. So I'm just trying to pull both boxes along then the pre fractured box to break on impact with the tube. Thanks you again For_Od_Force_v2.hipnc Quote Link to comment Share on other sites More sharing options...
mangi Posted June 16, 2013 Share Posted June 16, 2013 use the Glue Adjacent. For_Od_Force_v2_glue adjacent.hipnc Quote Link to comment Share on other sites More sharing options...
pxlfx Posted June 16, 2013 Author Share Posted June 16, 2013 Thanks again Mangi Quote Link to comment Share on other sites More sharing options...
mangi Posted June 16, 2013 Share Posted June 16, 2013 (edited) Sure, no sweat, Cheers Edited June 16, 2013 by mangi Quote Link to comment Share on other sites More sharing options...
