displacement custom control?
Hi,guys,
i have a shader question here.
i want to do some displacement on my rigidbody chunk to add detail.
let's say we have a cube,in the attatchment jpg ,it is a.(you can imagine it is a rigid chunk),
if i add noise displacement on it,i got b.
but,i do not want the top face get the displacement,because i hope the top face looks like a flat ground.
so i set the noise vector y to 0,and i got c.
the problem is the top face looks strange,the reason i think is the x z position of the top face changed,
the normal should changed too.
so,i set the normal vector y 0,then i got d,you can see,there is some change,but it did not solve the problem.
what can i do to get what i want?
i need your help.
thank you.
Peng Zhang.post-8141-0-89452800-1371629424_thumb.jp
shader_displacement6.hip
I think the way to go is not messing up with normals and positions.
If u are using the "displace along normal" node, just add an attribute in shops, that has a value of 0 where u don´t want displacement and 1 where u want.
Read that in shops using a parameter node with the attribute name in it, and multiply the displacement amout by this number.
