amination Posted June 22, 2013 Share Posted June 22, 2013 Hello! Recently I've added 2 more monitors to my machine and all my screens have been messed up ever since. I'm using Ubuntu Studio (GNOME 2.5), and I've tried the administrator display setting which I do not see any option for splitting workspace between each monitor. I'm actually a bit new with Linux yet, so any suggestion or recommendation would be fantastic. What it shows is one screen is completely blanked out, and the other 2 are mirrored from each other, except one displays larger icons. Has anyone had this problem before? What's the solution? Thanks a lot in advance. Quote Link to comment Share on other sites More sharing options...
amination Posted June 22, 2013 Author Share Posted June 22, 2013 Although, I did look through Ubuntu forums and haven't found anyone with similar issue. Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted June 24, 2013 Share Posted June 24, 2013 If you're using Nvidia card, then you should change the parameters in NVIDIA X Server Settings, under the X Server Display Configuration. Quote Link to comment Share on other sites More sharing options...
amination Posted June 30, 2013 Author Share Posted June 30, 2013 I'm not using Nvidia Card, it's ATI Radeon HD 4600. Should I look through the card's parameters for the matter too or it's just for Nvidia cards? Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted July 1, 2013 Share Posted July 1, 2013 Are you sure your cards hardware is able to support 3 screens? I had to upgrade my GTX570 to a 6xx series card as the 5xx series did not support more than 2 displays. I've just briefly searched for it and it seems that I am correct in my assumption: http://www.tomshardware.co.uk/forum/312500-33-monitors-4600 -dennis Quote Link to comment Share on other sites More sharing options...
amination Posted July 1, 2013 Author Share Posted July 1, 2013 I'm just wondering when you set-up 2+ monitors on your machine for Linux, did you adjust anything internally to set up workspaces on each screen or it automatically set it for you? My card supports 3 monitors without an error in Windows 7, that error I get is only in Linux. Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted July 2, 2013 Share Posted July 2, 2013 It's quite possible that you need to play with your xorg.conf to get things working. Just search the linux forums and you should find a ton of information about it. Nvidia drivers have a configuration tool that sets up your xorg.conf for you. That's how I did it. There should be an equivalent for ATI cards I suppose. -dennis Quote Link to comment Share on other sites More sharing options...
