jiahongyuan Posted June 22, 2013 Share Posted June 22, 2013 Hey guys, I set MSVCDir to the following two locations, but it does not work. Where is the correct location? Thanks C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\IDE Quote Link to comment Share on other sites More sharing options...
edward Posted June 23, 2013 Share Posted June 23, 2013 Neither, for two reasons: 1. You must use VS 2008 for Houdini 12.5 2. It needs to be the "VC" subdirectory 1 Quote Link to comment Share on other sites More sharing options...
WesleyE Posted June 23, 2013 Share Posted June 23, 2013 You could use VS2012 if you install 2008 and 2010 and select c90 in the preferences. It then uses the linker and compiler from VS2008. 1 Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted June 23, 2013 Share Posted June 23, 2013 (edited) There are couple topics on StackOverflow that mentions possibility to use VS2012 with older compilers that are shipped with WindowsSDK, but I think you may have a better chance of going with free VisualStudio2008 Express and using WindowsSDK (also free) to install 64-bit compiler, if you don't own full VS2008. Edited June 24, 2013 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted June 24, 2013 Share Posted June 24, 2013 On 6/23/2013 at 3:34 AM, edward said: Neither, for two reasons: 1. You must use VS 2008 for Houdini 12.5 2. It needs to be the "VC" subdirectory Edward when are you guys gonna move to VS2012? Not sure if you are eager to use the latest tools, but I was happy when our shared game engine and editor was upgraded to VS2012. Although for general art tools, I always had the freedom to use whatever as I was the owner, which was why I was using VS2012 as soon as it came out. Quote Link to comment Share on other sites More sharing options...
0rr Posted June 25, 2013 Share Posted June 25, 2013 On 6/24/2013 at 11:03 PM, magneto said: Edward when are you guys gonna move to VS2012? Not sure if you are eager to use the latest tools, but I was happy when our shared game engine and editor was upgraded to VS2012. Although for general art tools, I always had the freedom to use whatever as I was the owner, which was why I was using VS2012 as soon as it came out. Also C++11 some features are just convenient. 1 Quote Link to comment Share on other sites More sharing options...
edward Posted June 26, 2013 Share Posted June 26, 2013 On a personal note, I'd love to move to VS2012. However, there's still a lot of work to be done before that can happen. The bulk of the work is actually upgrading the build systems of all the third party dependencies that Houdini uses. Personally, I haven't found a single VS2008 project that upgraded successfully to VS2012 without tweaks. 1 Quote Link to comment Share on other sites More sharing options...
