Reverse the tranformations on building... or something
kleer001
I have this sop solver setup that places blocks on previous blocks within certain rules of transformation and rotation. It even has a simple "collision detection" check. The results are fine, but the thing flips around crazily.
I've tried several ways to accumulate the transformations so that the new piece is moved to the proper place, but it is eluding me. That way the animation of its building would look better.
Any ideas? I think it would have to do with some sort of transformation matrix or something. Maybe. Ugh, so lost.
slatsConstruct_05.hipnc
whatever you are doing inside the solver, I guess you are mainly asking about how to reverse the transform you are applying to your source geometry with any of the 19 xforms so that the resulting geo after adding new piece stays on the same place
you can simply add xform after adding the new piece and point it's parameters to active input of the switch4 node (it'll be one of 19 xforms you have)
then you can simply check Invert Transformation on that new xform
see the file
and you may need to change the logic you are using to build the blocks as now it'll not flip like crazy so the attribtransfer will not transfer different values per iteration and the evolution will stop easily
slatsConstruct_mod.hipnc
maybe create a point with 3 vectors before placing the building,
and then create a matrix from those 3 modified vectors,
and in vops do an extract transform on it to get the rotation and translation.
(and scale you ca do by measuring the vecors before making the new matrix)
