Problem with Denting Geometry on initial Impact in Sop Solver
pxlfx
Hi Guys
If anyone could help i would really appreciate it. For some reason on initial impact the sop solver doesn't dent the geometry even though it it shows it in impact data. The geometry dents no problem the second, third etc just not the first. Attached is a simple version of what I'm working on.
Thanks for looking at my post :)
sop_solver.hipnc
it does dent it on the initial impact as well, but because your deformation on impact points is only moving points in y-axis (Magnet SOP) you don't see it clearly since it is happening on vertical part of the door, so you may want to use other means to deform maybe based on impact normal or so
