convert(or fix) a houdini 11 file to run on 12.5
I got a houdini 11 file .hipnc that got many warnings when opening on houdini 12.5
warnings are in dopnetworks and other places, generally are Skipping unrecognized parameter
any easy way to fix this? as I'm still new ,what I guess is that these parameters names have changed from version to version
tell me how to convert the file,or at least a place to know "names" of each parameters at houdini 11 and 12.5 to convert them manually
thanks in advance
Mohamed
  • 2 weeks later...
There's no straightforward answer because nodes can change from one Houdini version to another as new improvements are introduced. For example the Pyro nodes are completely different because the way the solver itself works has changed. Other nodes have changed too but they have changed in different ways so there's no silver bullet to fix them all. If you need to keep things exactly the same then keep working in the older version of Houdini, or at least write out what you can to BGEO files so you don't have to setup some stuff again in the newer version of Houdini.
http://www.sidefx.com/docs/houdini11.0/nodes/dop/pyrosolver#parameters
http://www.sidefx.com/docs/houdini12.5/nodes/dop/pyrosolver#parameters
