How to add implicit point normals in VEX?
I know it's easy to do if you use VOPs. Just connecting N (input) to N (output) gives you normals the same way a Point SOP does.
But is there a way to replicate this in VEX? For example when using the Attrib Wrangle SOP?
@N = @N;[/CODE]
doesn't work. We should have the same capability in VEX.
