Is there a way to do per point morphing in Houdini using the Blend SOP
I checked Blend Shapes SOP and Sequence Blend SOP but they don't seem to allow having a per-point interpolation for the blend amount.
Is there a way to do this in Houdini? I know this is easy to do in VOPs but are there no built-in SOPs for this? If so, that's really surprising.
Guest mantragora
Also you recommend Point Wrangle SOP over VOPSOP? They are identical in speed, right?
Dive inside PointWrangle, what nodes you see there?
But is overriding VOP parameters with point attributes slow too?
Not really. It's slower than if you didn't override of course, but a lot faster than if you needed to evaluate local variables. The other reason for VEX/VOPs of course is that the Point SOP is not multi-threaded.
