Run a Python script when Houdini crashing?
Cuckon
The term wrap means launch it from something else. If it were Python you could use the subprocess module to start Houdini and then do something depending on what Houdini spits back.
import subprocess
status = subprocess.check_output('houdini')
if 'something to look for' in status:
[/CODE]
Then do something based on whatever Houdini spit back (the status variable). Another way would be to setup a watchdog running all the time that looks for the Houdini process and have it do something if there's no Houdini running.
