how can I get more detail for pyro?
zhangzx2006
Decrease the division size on the pyro (smoke) object node in the DOP network. If you're new to Houdini I suggest you start with the basics instead of jumping into some of the most complex parts of Houdini. If you have a good understanding of the basics then everything else will make more sense and be less frustrating.
http://www.sidefx.com/docs/houdini12.5/nodes/dop/smokeobject#parameters
