magneto Posted September 5, 2013 Share Posted September 5, 2013 Hi, I tried to bring the collision geometry of an rbd object into SOPs but couldn't do it. Is this possible? Not sure if it matters whether it's bullet or RBD collision but I turned off geometry display and turned on collision display. But I am not sure if this is strictly for visualization or if it actually changes the output of the rbd node? Thanks Quote Link to comment Share on other sites More sharing options...
cwhite Posted September 5, 2013 Share Posted September 5, 2013 The guide geometry is just for visualization, but if you want to e.g. get the same convex hull shape that the Bullet Solver computes, you can generate that using the ShrinkWrap SOP. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted September 5, 2013 Author Share Posted September 5, 2013 Thanks cwhite, I was actually interested in getting other collisions like the aligned box, cylinder, capsule, etc I changed the option to Fetch Geometry in the dopimport node, but like you said I didn't get the collision. But there has to be a way to get this mesh, right? Quote Link to comment Share on other sites More sharing options...
cwhite Posted September 5, 2013 Share Posted September 5, 2013 Ah, I think I found it - you can set the Geometry Data Path to Geometry/BulletData to fetch the guide geometry from the Bullet solver. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted September 5, 2013 Author Share Posted September 5, 2013 Thanks cwhite, I understand it now. I didn't know it was stored there, and was accessible Quote Link to comment Share on other sites More sharing options...
Keithtron Posted July 6, 2017 Share Posted July 6, 2017 I know this is an old thread, but is there any way to get the convex hull geo with the per-piece name attributes intact? The convex hulls seem a bit useless without the name attr info, for most scenarios. Quote Link to comment Share on other sites More sharing options...
cwhite Posted July 7, 2017 Share Posted July 7, 2017 If you only need this for convex hulls, just do a shrinkwrap SOP in a foreach loop and transfer any attributes that you need Quote Link to comment Share on other sites More sharing options...
