zveris Posted May 16, 2004 Share Posted May 16, 2004 Is there a way in point sop to set the up vector attribute to be oriented along one of the connected edges, specificly along the edge going to point with the smallest ID nr? Zveris Quote Link to comment Share on other sites More sharing options...
Marc Posted May 17, 2004 Share Posted May 17, 2004 You may want to try the Flo tool from the codex (http://odforce.net/codex/geometry.php) which will point your normals at each successive point. Once you've done this you can convert the point normal to an upvector. Cheers Marc Quote Link to comment Share on other sites More sharing options...
