gramx Posted September 26, 2013 Share Posted September 26, 2013 Hi, I am looking into modifying the whitewater solver in Houdini. Currently If you generate Foam in you simulations you will find that areas of the simulation dip beneath the surface and disappear creating a popping effect which I have scene in several simulations. If you also calculate bubbles then these foam particles turn into bubbles beneath the surface and turn back to foam when they reach the surface. This is a nice feature however what I want to be able to do is calculate Foam on the surface and have it always buoyant so it never dips below the surface. Now I have dived into the whitewater solver and haven't yet been able to figure out which nodes are controlling the Foam particles and there transition into bubbles. I think this would be a very useful feature. Has anyone got any ideas on how to do this? Thanks Graham Quote Link to comment Share on other sites More sharing options...
Skybar Posted September 26, 2013 Share Posted September 26, 2013 (edited) Now I have dived into the whitewater solver and haven't yet been able to figure out which nodes are controlling the Foam particles and there transition into bubbles. In the SOP Solver called "classify_particles", inside the whitewatersolver. edit: Also, you could probably Ray SOP the foam particles to the surface. Then they will always stay "floating". Edited September 26, 2013 by Skybar Quote Link to comment Share on other sites More sharing options...
johner Posted September 26, 2013 Share Posted September 26, 2013 Have you already increased the size of the foam layer by increasing the FoamDepth parameter? Cranking the bubble buoyancy way up also helps keep bubbles on the surface. edit: Also, you could probably Ray SOP the foam particles to the surface. Then they will always stay "floating". You can use the GasParticleMoveToIso DOP to snap the foam particles to the surface field very quickly. You will need to be careful because the transition to foam can make the snapping very obvious (which is why it isn't part of the default solver). Quote Link to comment Share on other sites More sharing options...
gramx Posted September 28, 2013 Author Share Posted September 28, 2013 Thanks Skybar I will check out the classify particles node! Thanks johner In my latest sims I have increases the foam depth and cranked up the buoyancy of the foam which does help! I wanted to try and get rid of the bubbles altogether as I sometimes find that I have millions of them under the surface which I never render! Quote Link to comment Share on other sites More sharing options...
StopTheRain Posted September 30, 2014 Share Posted September 30, 2014 Just wanted to add something to that year old thread.Topic starter mentioned problem when large groups of foam particles disappear suddenly and re-appear again. I have encountered the same problem with my simulation and no recipe described here (short of sticking particles to the surface with GasParticleMoveToIso DOP) helps. And I have seen the same problem with white water simulatios that other people are working on. Particles in whitewater solver DOP get classified into foam, spray and bubbles classes based on their proximity to surface. That surface volume is generated in whitewater source SOP and gets pulled into DOPs in whiteWaterSolver DOP | fetch_surface DOP | object_merge_1 SOP. Sometimes at least in my case that object merge fails to read "surface volume", and as a result particles at current time step get classified based on their proximity to the surface generated for one of the previous time steps. My fix for that is to generate separate output from white water source object consisting only of "surface" volume and set that as an input for above mentioned object merge SOP inside whitewater solver.Not sure that I will have luck re-creating that situation in simple example .hip file to send bug report to SIde Effects. Anyway that fix might help somebody. Quote Link to comment Share on other sites More sharing options...
GrayHare Posted November 13, 2014 Share Posted November 13, 2014 Just wanted to add something to that year old thread. Topic starter mentioned problem when large groups of foam particles disappear suddenly and re-appear again. I have encountered the same problem with my simulation and no recipe described here (short of sticking particles to the surface with GasParticleMoveToIso DOP) helps. And I have seen the same problem with white water simulatios that other people are working on. Particles in whitewater solver DOP get classified into foam, spray and bubbles classes based on their proximity to surface. That surface volume is generated in whitewater source SOP and gets pulled into DOPs in whiteWaterSolver DOP | fetch_surface DOP | object_merge_1 SOP. Sometimes at least in my case that object merge fails to read "surface volume", and as a result particles at current time step get classified based on their proximity to the surface generated for one of the previous time steps. My fix for that is to generate separate output from white water source object consisting only of "surface" volume and set that as an input for above mentioned object merge SOP inside whitewater solver. Not sure that I will have luck re-creating that situation in simple example .hip file to send bug report to SIde Effects. Anyway that fix might help somebody. Thanks stoptherain's tips:) I faced the same problem, will follow your way to deal with it. Quote Link to comment Share on other sites More sharing options...
